Jean-Marie Renouard 8fb9195c4f
Merge pull request #525 from grooverdan/qc
query_cache off with query_cache_type=OFF OR query_cache_size=0
2021-01-27 21:28:18 +01:00
build merged 2020-05-02 16:01:37 +02:00
Vagrant Removing windows end of lines 2020-05-04 11:01:34 +02:00
.travis.yml merged 2020-05-02 16:01:37 +02:00
mysqltuner.pl Merge pull request #525 from grooverdan/qc 2021-01-27 21:28:18 +01:00
README.md Update README.md 2020-12-29 15:14:36 +01:00
USAGE.md Update USAGE.md 2020-09-15 15:26:15 +02:00
vulnerabilities.csv local commit 2020-05-02 15:56:26 +02:00
  • MariaDB 10.5 (partial support)
  • MariaDB 10.2 (full support)
*** MINIMAL REQUIREMENTS ***
