Matija Nalis 92e2dbb12b removed ununused mysql_micro_version_le()
duplicate of mysql_version_le()
2022-12-30 14:15:58 +01:00
.github/workflows New workflow 2022-04-04 02:32:15 +02:00
build Installer script for updating CVE list 2022-12-29 19:07:53 +01:00
mysqltuner.pl removed ununused mysql_micro_version_le() 2022-12-30 14:15:58 +01:00
README.md ERROR 1054 #615 2022-11-30 14:37:57 +01:00
USAGE.md Update Vulnerabilities list 2022-12-29 05:11:31 +01:00
vulnerabilities.csv Update Vulnerabilities list 2022-12-29 05:13:02 +01:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
