Major Hayden 9341faf56a Correct table_cache_var bug
Fixes #49 by correcting a small error from #48. Sorry, folks!
2014-06-05 20:45:16 -05:00
mysqltuner.pl Correct table_cache_var bug 2014-06-05 20:45:16 -05:00
README.md Converted README from text to Markdown. 2014-02-21 10:52:51 -06:00
  • MySQL 6.0 (partial support)
wget mysqltuner.pl
* OS and OS version
* Exact MySQL version
* The full text of the error
