Default to reading last 30000 lines. If reading from file estimate that average line length is 80 characters and read based that far back from the end of file. |
| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mtlogo.png | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
MySQL 8 (partial support, password checks don't work)
MySQL 5.7 (full support)
MySQL 5.6 (full support, no more MySQL support)
MySQL 5.5 (full support, no more MySQL support)
MariaDB 10.5 (full support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
MariaDB 10.2 (full support)
MariaDB 10.1 (full support, no more MySQL support)
MariaDB 10.0 (full support, no more MySQL support)
MariaDB 5.5 (full support, no more MariaDB support)
Percona Server 5.6 (full support)
Percona XtraDB cluster (partial support, no test environment)
Galera replication (partial support, no test environment)
MySQL 3.23, 4.0, 4.1, 5.0, 5.1, 5.5 (partial support - deprecated version)
Windows is not supported at this time (Help wanted !!!!!)
Cloud based is not supported at this time (Help wanted !!!!!)
*** MINIMAL REQUIREMENTS ***
Hi directadmin user!
- Fedora Core 30 / Docker
