2022-03-12 19:13:32 +01:00
.github/workflows Update actions/checkout action to v3 2022-03-12 17:48:22 +00:00
mysqltuner.pl False impression on key buffer usage 2022-03-12 19:13:32 +01:00
README.md Adding AHA section for HTML generation 2022-03-11 14:38:08 +01:00
USAGE.md Update USAGE.md 2022-02-08 00:33:33 +01:00
vulnerabilities.csv Update Vulnerabilities list 2022-02-04 16:01:22 +01:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
