2023-04-25 23:05:47 +02:00
.github/workflows Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
build Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
templates Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
Vagrant Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
.gitignore Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
CODE_OF_CONDUCT.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
CONTRIBUTING.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
INTERNALS.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
mysqltuner.pl Adding stop after dumping option 2023-04-25 23:05:47 +02:00
README.it.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
README.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
USAGE.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
vulnerabilities.csv Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
  • MariaDB 10.9 (full support)
  • MariaDB 10.8 (full support)
  • MariaDB 10.7 (full support)
  • MariaDB 10.6 (full support)
  • A MySQL server installation
