Include calculation of Aria index size based of *.MAI files. Use find -0 | xargs -0 to allow for space containing names. Quote datadir in find in case it had spaces. Use xargs -r (GNU extension) (supported Linux, FreeBSD, OpenBSD, NetBSD, not Solaris, not OSX) to not run if there's no files that match. This prevents it running the total of the current directory if there are no M[YA]I files. A total size of 0 for Aria or MyISAM indexes isn't a problem because: * MySQL-5.[567] used MyISAM system tables which have indexes, so 0 wasn't possible (except for remote user without mysql.* access). * 0 size of index is equally likely to be 0 tables of this type (e.g. MySQL-8.0, or MariaDB-10.4+ (Aria default, not MyISAM)). Setting total_aria_indexes=1 when it was previously 0 is misleading. Aria was never called AriaDB despite the apparent convention in other storage engines so use just Aria, or Aria Storage Engine in messages. Differentiate between Aria not available and disabled in report. |
| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mtlogo.png | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
MySQL 8 (partial support, password checks don't work)
MySQL 5.7 (full support)
MySQL 5.6 (full support)
MySQL 5.5 (full support, no more MySQL support)
MariaDB 10.5 (partial support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
MariaDB 10.2 (full support)
MariaDB 10.1 (full support)
MariaDB 10.0 (full support, 6 last month support)
MariaDB 5.5 (full support, no more MariaDB support)
Percona Server 5.6 (full support)
Percona XtraDB cluster (partial support, no test environment)
Galera replication (partial support, no test environment)
MySQL 3.23, 4.0, 4.1, 5.0, 5.1, 5.5 (partial support - deprecated version)
Windows is not supported at this time (Help wanted !!!!!)
Cloud based is not supported at this time (Help wanted !!!!!)
*** MINIMAL REQUIREMENTS ***
Hi directadmin user!
- Fedora Core 30 / Docker
