Related to #661 - message is OK - and other changes to skip checks work as intended, but without a return here, it will look for local log files. |
| .github/workflows | ||
| build | ||
| examples/github/result | ||
| templates | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| FEATURES.md | ||
| INTERNALS.md | ||
| mtlogo.png | ||
| mysqltuner.png | ||
| README.fr.md | ||
| README.it.md | ||
| README.ru.md | ||
| renovate.json | ||
| SECURITY.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
MySQL 5.7 (full support)
MariaDB 10.11 (full support)
MariaDB 10.10 (full support)
MariaDB 10.9 (full support)
MariaDB 10.8 (full support)
MariaDB 10.7 (full support)
MariaDB 10.6 (full support)
MariaDB 10.5 (full support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
RockDB
Archive
Spider
ColummStore
TokuDB
XtraDB
Connect
Hi directadmin user!
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
- A MySQL server installation
- Fedora Core 30 / Docker
- Fork this Github project
- Make a new branch
- Make your changes
- Push it back to your repo
