Jean-Marie Renouard 9adb7d6efd Update Vulnerabilities list
Indenting mysqltuner
Update Usage information
2023-03-14 21:40:13 +00:00
.github/workflows fix: adding credentials 2023-03-14 21:06:59 +00:00
build Installer script for updating CVE list 2022-12-29 19:07:53 +01:00
test_db@d01cb62fcf fix: adding localhost host 2023-03-14 20:23:07 +00:00
mysqltuner.pl Update Vulnerabilities list 2023-03-14 21:40:13 +00:00
README.md ERROR 1054 2023-02-02 08:22:07 +01:00
vulnerabilities.csv Update Vulnerabilities list 2023-03-14 21:40:13 +00:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
