Jean-Marie Renouard 9daf5cf42e Merge pull request #262 from kn007/patch-1
Non importance changes
2016-10-27 21:16:16 +02:00
mysqltuner.pl Non importance changes 2016-10-24 17:25:07 +08:00
README.md Update indicator number 2016-10-18 15:18:28 +02:00
README.ru.md Update README.ru.md 2016-10-10 13:20:17 +02:00
vulnerabilities.csv Full support performance schema 2016-10-18 14:55:13 +02:00
MySQLTuner is maintained and indicator collect is increasing week after week supporting a lot of configuration sush as Galera Cluster, TokuDB,        Performance schema, Linux OS metrics, InnoDB, MyISAM, Aria, ...
