Jean-Marie Renouard a1c1624b81 Update .travis.yml
2019-10-16 20:02:43 +02:00
build Missing password is not recognized #412 2019-10-03 23:15:31 +02:00
Vagrant Percona Server 8.0 - better support 2019-10-02 00:07:46 +02:00
.travis.yml Update .travis.yml 2019-10-16 20:02:43 +02:00
mysqltuner.pl SCALAR ref while strict refs 2019-10-04 12:10:16 +02:00
README.md Update README.md 2019-10-03 23:58:06 +02:00
USAGE.md Update Vulnerabilities list 2019-09-25 20:05:45 +00:00
vulnerabilities.csv Update Vulnerabilities list 2019-09-25 20:07:18 +00:00
  • MySQL 8 (full support, password checks don't work)
  • MariaDB 10.2 (full support)
  • Percona Server 8.0 (full support, password checks don't work)
*** MINIMAL REQUIREMENTS ***
