2019-10-03 21:04:12 +02:00
build Add note about join_buffer_size #434 2019-10-03 21:04:12 +02:00
Vagrant Percona Server 8.0 - better support 2019-10-02 00:07:46 +02:00
.travis.yml Add test env for MariaDB 10.4 (GA) 2019-07-25 12:38:43 +02:00
INTERNALS.md Update error log file analysis 2019-09-26 00:41:10 +02:00
mysqltuner.pl Add note about join_buffer_size #434 2019-10-03 21:04:12 +02:00
README.md Update README.md 2019-10-02 01:35:37 +02:00
USAGE.md Update Vulnerabilities list 2019-09-25 20:05:45 +00:00
vulnerabilities.csv Update Vulnerabilities list 2019-09-25 20:07:18 +00:00
  • MariaDB 10.2 (full support)
  • MariaDB 5.5 (no more support)
