2023-03-03 15:46:52 +01:00
.github/workflows New workflow 2022-04-04 02:32:15 +02:00
build Installer script for updating CVE list 2022-12-29 19:07:53 +01:00
mysqltuner.pl nice looking CSV format 2023-03-03 15:46:52 +01:00
README.md ERROR 1054 2023-02-02 08:22:07 +01:00
USAGE.md Update Vulnerabilities list 2022-12-29 05:11:31 +01:00
vulnerabilities.csv Update Vulnerabilities list 2022-12-29 05:13:02 +01:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
