2021-03-30 11:54:30 +02:00
build merged 2020-05-02 16:01:37 +02:00
Vagrant Removing windows end of lines 2020-05-04 11:01:34 +02:00
.travis.yml travis: add percona supported versions 2021-02-01 15:11:34 +11:00
mysqltuner.pl Update mysqltuner.pl 2021-03-30 11:54:30 +02:00
README.md Update README.md 2021-03-15 10:06:44 +01:00
USAGE.md Update Vulnerabilities list 2021-02-05 08:57:50 +01:00
vulnerabilities.csv Update Vulnerabilities list 2021-02-05 15:25:09 +01:00
  • MySQL 5.6 (full support, no more MySQL support)
  • MariaDB 10.2 (full support)
  • MariaDB 10.1 (full support, no more MariaDB support)
  • MariaDB 10.0 (full support, no more MariaDB support)
*** MINIMAL REQUIREMENTS ***
