2016-01-27 18:37:53 +01:00
build Bug fix for issue #145 2016-01-19 22:39:44 +00:00
.travis.yml Update .travis.yml 2015-11-13 15:30:08 +00:00
INTERNALS.md Adding CVE detection support 2016-01-06 00:59:18 +01:00
mysqltuner.pl Removing annoying message in mysql 2016-01-27 17:22:49 +01:00
README.md Update README.md 2016-01-22 11:29:54 +01:00
USAGE.md Adding CVE detection support 2016-01-06 00:55:54 +01:00
vulnerabilities.csv Bug fix for issue #145 2016-01-19 22:39:44 +00:00
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
MySQLTuner contains a Vagrant configuration for test purpose and development
