| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mysqltuner.png | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
MySQLTuner supports in this last version ~250 indicators for MySQL/MariaDB/Percona Server.
MySQLTuner is maintained and indicator collect is increasing week after week supporting a lot of configuration sush as ,
, Linux OS metrics,
You can found more details on this indicators
- MySQL 5.7 (full support)
- MySQL 5.6 (full support)
- MySQL 5.5 (full support)
- MariaDB 10.1 (full support)
- MariaDB 10.0 (full support)
- Fedora Core 23 / MySQL 5.6
- Fedora Core 23 / MySQL 5.7
- vagrant up
- Start vagrant
- vagrant up
