Jean-Marie Renouard b33c70338c fix: revert changes
2023-03-23 10:48:23 +00:00
.github/workflows fix: revert changes 2023-03-23 10:48:23 +00:00
examples/github/result Commit example result 2023-03-22 14:24:34 +00:00
test_db@d01cb62fcf fix: Markdown rules fixed 2023-03-23 10:02:02 +00:00
.gitignore fix: Markdown rules fixed 2023-03-23 10:02:02 +00:00
mysqltuner.pl Merge pull request #633 from longradix/master 2023-03-23 10:40:59 +01:00
README.md fix: Markdown rules fixed 2023-03-23 10:02:02 +00:00
vulnerabilities.csv Updates CVS and docs 2023-03-22 16:34:10 +01:00
  • MariaDB 10.9 (full support)
  • MariaDB 10.8 (full support)
  • MariaDB 10.7 (full support)
  • MariaDB 10.6 (full support)
  • A MySQL server installation
