2016-08-08 17:40:53 +02:00
INTERNALS.md Update INTERNALS.md 2016-07-07 09:49:29 +02:00
mysqltuner.pl #227 Stopping MySQL tuner when SELECT VERSION doesnt return any value. This indicates that user doent get enough privileges 2016-08-08 17:40:53 +02:00
README.md Update README.md 2016-06-16 11:18:09 +02:00
vulnerabilities.csv Update vulnerability list 2016-08-08 17:16:07 +02:00
  • MySQL 5.7 (partial support)
