2016-08-29 14:26:40 +02:00
.travis.yml Revert "removing mariaDB 10.1 as test from travis - temporary" 2016-08-29 14:26:40 +02:00
INTERNALS.md Update INTERNALS.md 2016-07-07 09:49:29 +02:00
mysqltuner.pl increment version 2016-08-26 11:02:15 +02:00
README.md Update README.md 2016-08-18 09:20:49 +02:00
vulnerabilities.csv Update vulnerabilities list 2016-08-25 16:33:58 +02:00
  • MySQL 5.7 (partial support)
