| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
- MySQL 5.7 (partial support)
- MySQL 5.6 (full support)
- MariaDB 10.0 (full support)
- MySQL 5.5 (full support)
- MySQL 5.1 (full support)
MySQLTuner contains a Vagrant configuration for test purpose and development
- Start vagrant
- vagrant up
