Jean-Marie Renouard b8effe6410
Merge pull request #516 from grooverdan/supported_versions
MariaDB-10.1 EOL, MariaDB-10.5 is GA
2020-12-08 08:29:44 +01:00
build merged 2020-05-02 16:01:37 +02:00
Vagrant Removing windows end of lines 2020-05-04 11:01:34 +02:00
.travis.yml merged 2020-05-02 16:01:37 +02:00
mysqltuner.pl MariaDB-10.1 EOL, MariaDB-10.5 is GA 2020-12-08 15:25:59 +11:00
README.md Update README.md 2020-10-08 11:48:00 +02:00
USAGE.md Update USAGE.md 2020-09-15 15:26:15 +02:00
vulnerabilities.csv local commit 2020-05-02 15:56:26 +02:00
  • MariaDB 10.5 (partial support)
  • MariaDB 10.2 (full support)
*** MINIMAL REQUIREMENTS ***
