Jean-Marie RENOUARD ba87f9492a Update Usage file
2015-07-15 11:10:43 +02:00
misc Documenting a bit 2015-06-21 16:09:00 -04:00
CONTRIBUTING.md Adding a small CONTRIBUTING file 2015-06-16 15:20:36 +02:00
mysqltuner.pl Issue #90 2015-07-15 11:09:51 +02:00
README.md README format errorswq 2015-06-16 15:45:34 +02:00
  • MySQL 5.5 (partial support)
  • MySQL 5.6 (partial support)
  • MySQL 6.0 (partial support)
* OS and OS version
* Exact MySQL version
* The full text of the error
