2023-03-22 15:54:59 +01:00
.github/workflows fix: exec levels and action naming 2023-03-22 15:54:59 +01:00
build feat: try to auto commit result into repo 2023-03-18 17:57:06 +01:00
examples/github/result Commit example result 2023-03-22 13:59:39 +00:00
mysqltuner.pl feat: try to auto commit result into repo 2023-03-18 17:57:06 +01:00
README.md feat: Typos fixes 2023-03-22 14:57:08 +01:00
vulnerabilities.csv feat: try to auto commit result into repo 2023-03-18 17:57:06 +01:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
  • A MySQL server installation
