Jean-Marie Renouard c94906580f
Merge pull request #659 from ryno83/patch-2
Confusion between the name of the variable skip_name_resolve and the …
2023-05-23 07:16:38 +02:00
.github/workflows Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
templates Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
INTERNALS.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
mysqltuner.pl Confusion between the name of the variable skip_name_resolve and the recommendations 2023-05-22 13:53:47 -04:00
README.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
vulnerabilities.csv Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
  • MariaDB 10.9 (full support)
  • MariaDB 10.8 (full support)
  • MariaDB 10.7 (full support)
  • MariaDB 10.6 (full support)
  • A MySQL server installation
