Jean-Marie RENOUARD cd636fc28f Update
2016-08-09 11:43:09 +02:00
INTERNALS.md Update vulnerabilities list 2016-06-10 10:18:21 +02:00
mysqltuner.pl Reword a message 2016-06-16 10:33:03 +02:00
README.md Update README.md 2016-06-16 11:18:09 +02:00
vulnerabilities.csv Update 2016-08-09 11:43:09 +02:00
  • MySQL 5.7 (partial support)
