Jean-Marie Renouard d7c44dbf28
Merge pull request #3 from jmrenouard/Fix-export-sys-dollar-view
Fix export sys dollar view
2023-06-17 22:39:09 +02:00
FEATURES.md Laste version with clean FEATURES.md list 2023-06-11 12:09:10 -04:00
mysqltuner.pl update version number 2023-06-17 22:37:09 +02:00
README.md doc: fixing presentation 2023-06-07 19:18:03 +02:00
USAGE.md Updates doc and CVE 2023-06-07 19:29:41 +02:00
  • MariaDB 10.9 (full support)
  • MariaDB 10.8 (full support)
  • MariaDB 10.7 (full support)
  • MariaDB 10.6 (full support)
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
