Jean-Marie Renouard da9c37b2e5
Merge pull request #738 from Murl080/patch-1
Correct physical memory comparison
2023-10-09 15:12:13 +02:00
Makefile Last updates 2023-09-09 12:08:45 +02:00
mysqltuner.pl Correct physical memory comparison 2023-10-09 15:05:07 +02:00
README.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
README.ru.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
USAGE.md cannot set $opt{myisamstat} == 0 #713 2023-09-26 22:50:57 +02:00
vulnerabilities.csv Last vulnerabilites list 2023-09-09 08:25:53 +02:00
Anurag's GitHub stats
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
