2018-09-26 07:31:19 +00:00
build Adding test database for test purpose 2018-09-23 07:57:45 +00:00
.travis.yml Update travis yml 2018-09-23 15:18:13 +00:00
INTERNALS.md Fixing important performance issue during collecting metrics 2018-09-20 13:11:34 +00:00
mysqltuner.pl MySQLTuner dont understand Thread Pool in Percona Server 5.7 #386 2018-09-26 07:31:19 +00:00
README.md Typo fixes 2018-09-23 06:36:30 +00:00
runAudit.sh New script for running remote audit and generate HTML report 2018-09-24 16:12:40 +02:00
template_example.tpl New simple modele for HTML result 2018-09-23 15:31:09 +00:00
txt2html.pl New script for running remote audit and generate HTML report 2018-09-24 16:12:40 +02:00
USAGE.md New option tbstat 2018-09-20 12:51:07 +00:00
Test result are avalaible here: Travis CI/MySQLTuner-perl
  • MariaDB 10.2 (full support)
