2022-03-11 09:42:01 +01:00
.github/workflows Create exec.yml 2021-07-05 08:45:01 +02:00
mysqltuner.pl False impression on key buffer usage 2022-03-11 09:42:01 +01:00
README.md List unsupported storage engine 2022-02-08 00:15:59 +01:00
USAGE.md Update USAGE.md 2022-02-08 00:33:33 +01:00
vulnerabilities.csv Update Vulnerabilities list 2022-02-04 16:01:22 +01:00
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
