Use of implicit split to @_ is deprecated at /tmp/mysqltuner.pl line 3243 (#1) (D deprecated, W syntax) It makes a lot of work for the compiler when you clobber a subroutine's argument list, so it's better if you assign the results of a split() explicitly to an array (or list). |
| build | ||
| Vagrant | ||
| .perltidy | ||
| basic_passwords.txt | ||
| CODE_OF_CONDUCT.md | ||
| CONTRIBUTING.md | ||
| INTERNALS.md | ||
| mysqltuner.png | ||
| README.ru.md | ||
| template_example.tpl | ||
| USAGE.md | ||
| vulnerabilities.csv | ||
- MySQL 5.7 (partial support)
- MySQL 5.6 (full support)
- MySQL 5.5 (full support)
- MariaDB 10.0 (full support)
- Fedora Core 23 / MySQL 5.6
- Fedora Core 23 / MySQL 5.7
- vagrant up
- Start vagrant
- vagrant up
