2023-09-09 11:13:41 +02:00
.github/workflows New Github actions 2023-09-09 11:13:19 +02:00
Makefile New Github actions 2023-09-09 11:02:46 +02:00
mysqltuner.pl Merge pull request #723 from spithash/patch-1 2023-09-09 08:27:47 +02:00
README.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
README.ru.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
USAGE.md Last updates 2023-09-09 08:25:09 +02:00
vulnerabilities.csv Last vulnerabilites list 2023-09-09 08:25:53 +02:00
Anurag's GitHub stats
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
