2023-09-04 15:19:14 +02:00
.gitignore Adding detection of non primary key tables 2023-06-22 23:00:28 +02:00
FEATURES.md Update code and CVEs 2023-07-06 08:19:29 +02:00
mysqltuner.pl Updates USAGE and version number 2023-08-16 07:38:34 +02:00
README.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
README.ru.md clarify that innodb_stats_on_metadata is actual only in MySQL<=5.6 2023-07-25 22:52:58 +02:00
USAGE.md Updates USAGE and version number 2023-08-16 07:38:34 +02:00
Anurag's GitHub stats
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
