Major Hayden efaf57383d Merge pull request #53 from Baebeca/master
minor format fixes
2014-08-10 12:47:08 -05:00
mysqltuner.pl Update mysqltuner.pl 2014-08-10 19:18:16 +02:00
README.md Fixed wget command. 2014-07-26 14:55:11 +02:00
  • MySQL 6.0 (partial support)
* OS and OS version
* Exact MySQL version
* The full text of the error
