2015-08-18 18:44:59 +02:00
misc Adding information about checks performed by MySQLTuner 2015-08-18 18:44:59 +02:00
CONTRIBUTING.md Adding a small CONTRIBUTING file 2015-06-16 15:20:36 +02:00
mysqltuner.pl Adding information about checks perform by MySQLTuner 2015-08-18 18:37:59 +02:00
README.md Update readme 2015-08-18 18:16:49 +02:00
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
* OS and OS version
* Exact MySQL version
* The full text of the error
