build | ||
.gitignore | ||
.perltidy | ||
.travis.yml | ||
basic_passwords.txt | ||
CONTRIBUTING.md | ||
INTERNALS.md | ||
LICENSE | ||
mysqltuner.pl | ||
README.md | ||
README.ru.md | ||
template_example.tpl | ||
USAGE.md |
- MySQL 5.7 (partial support)
- MySQL 5.6 (full support)
- MariaDB 10.0 (full support)
- MySQL 5.5 (full support)
- MySQL 5.1 (full support)
