Jean-Marie Renouard fa6fdfb5cf
Merge pull request #704 from longradix/master
Update README.md
2023-07-07 14:50:54 +02:00
.gitignore Adding detection of non primary key tables 2023-06-22 23:00:28 +02:00
CODE_OF_CONDUCT.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
CONTRIBUTING.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
FEATURES.md Update code and CVEs 2023-07-06 08:19:29 +02:00
INTERNALS.md Update INTERNALS.md 2023-06-19 10:28:55 +02:00
mysqltuner.pl update version 2023-07-07 09:14:11 +02:00
README.it.md Rearrange UNIX rights 2023-04-12 22:06:34 +02:00
README.md Update README.md 2023-07-07 11:16:55 +02:00
USAGE.md Update code and CVEs 2023-07-06 08:19:29 +02:00
Anurag's GitHub stats
Metadata statistic updates can strongly impact performance of database servers. Be sure that innodb_stats_on_metadata is disabled.
You can check its values via:
$ cat /proc/sys/fs/aio-*
65536
2305
fs.aio-max-nr = 1048576
To activate the new setting:
$ sysctl -p /etc/sysctl.conf
  • A MySQL server installation
