2016-03-22 15:20:47 +01:00
.travis.yml Update .travis.yml 2016-01-28 09:29:22 +01:00
INTERNALS.md Update INTERNALS.md 2016-03-22 14:49:22 +01:00
mysqltuner.pl Adding threadpool information #138 2016-03-22 15:20:18 +01:00
README.md Update README.md 2016-01-27 19:18:39 +01:00
USAGE.md Update vulnerabilities list 2016-02-24 19:52:26 +01:00
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
