2014-10-25 10:20:21 +00:00
mysqltuner.pl Merge 85393335ce into d030d9f340 2014-10-25 10:20:21 +00:00
README.md Fixed wget command. 2014-07-26 14:55:11 +02:00
  • MySQL 6.0 (partial support)
* OS and OS version
* Exact MySQL version
* The full text of the error
