Jean-Marie Renouard ff917fba8c Update INTERNALS.md
2015-08-19 14:38:28 +02:00
CONTRIBUTING.md Update CONTRIBUTING.md 2015-08-18 18:55:06 +02:00
INTERNALS.md Update INTERNALS.md 2015-08-19 14:38:28 +02:00
mysqltuner.pl Issue #104 /proc/meminfo is not language specific. 2015-08-19 09:51:22 +02:00
README.md Update readme 2015-08-18 18:16:49 +02:00
  • MySQL 5.7 (partial support)
  • MySQL 5.1 (full support)
* OS and OS version
* Exact MySQL version
* The full text of the error
