- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- NoSQL
- RDBMS
- SSH: see awesome-ssh
- Resources
See also: IT Asset Management
- Web hosting
- DNS
- Server
DNS
Domains
Identity Management - LDAP
- OpenDJ - Fork of OpenDS.
- Kanidm - A simple and secure identity management platform. (Source Code)
MPL-2.0Rust - KeyCloak - Open Source Identity and Access Management. (Source Code)
GPL-3.0Perl - bolo - A Do-it-Yourself monitoring framework built to gather metrics, mine data and report on the systems in your network.
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
Wikis
