- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- SSH: see awesome-ssh
- Resources
See also: IT Asset Management
Web hosting
- Froxlor - Lightweight server management software with Nginx and PHP-FPM support. (Source Code)
GPL-3.0Shell/Perl/Other
Server
LGPL-2.1C - Webmin - Web-based interface for system administration for Unix. (Source Code)
DNS - Control Panels
DNS server control panels.
DNS - Domain Management
MITPython
Identity Management - LDAP
- OpenDJ - Fork of OpenDS.
GPL-3.0Perl - Bosun - Monitoring and alerting system by Stack Exchange (Source Code, Documentation)
Collectors only
Dashboards
Storage
Wikis
