| .hecat | ||
| Makefile | ||
- Client management
- Metrics & Metric Collection
- Newsletters
- Remote Desktop Clients
- Blogs
- Books
- Newsletters
MITRuby
AGPL-3.0C/C++
Related: IT Asset Management
Apache-2.0C#/PowerShell
GPL-2.0/OtherPerl/Shell/Other - Fog - Cloning/imaging solution/rescue suite. (Source Code)
GPL-3.0PHP/Shell
- Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (SOurce Code)
- CFEngine - Configuration management system for automated configuration and maintenance of large-scale computer systems. (Source Code)
- Chef - Configuration management tool using a pure-Ruby, domain-specific language (DSL) for writing system configuration "recipes". (Source Code)
- Puppet - Software configuration management tool which includes its own declarative language to describe system configuration. (Source Code)
- Salt - Event-driven IT automation, remote task execution, and configuration management software. (Source Code)
- Kroki - API for generating diagrams from textual descriptions. (Source Code)
MITJava - Mermaid - Javascript module with a unique, easy, shorthand syntax. Integrates into several other tools like Grafana.
BSD-3-ClauseJava
BSD-3-ClauseC
Related: DNS - Servers
MITPHP
OLDAP-2.8C
GPL-3.0C
MITGo
GPL-3.0PHP
GPL-2.0Python
Public Key Infrastructure - PKI
Apache-2.0Python - easy-rsa - bash script to build and manage a PKI CA.
GPL-2.0bash - openxpki - A software stack based on perl and openssl to run a PKI/trust center with an enterprise-grade feature set.
Apache-2.0perl - Smallstep Certificates - A private certificate authority (X.509 & SSH) and related tools for secure automated certificate management.
Apache-2.0go - TinyPki is a compact and secure PKI, designed for Home, Lab, and Development environments, enabling you to effortlessly create a Root Certificate Authority and generate certificates to fulfill various requirements.
MITGo
GPL-3.0C++
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
BSD-2-ClauseC
