- Configuration Management
- Identity Management - Single Sign-On (SSO)
- Metrics & Metric Collection
- Miscellaneous
- Remote Desktop Clients
Build automation.
MITRuby
Backup software.
AGPL-3.0C/C++
MIT/Apache-2.0Python
_See also: /r/chatops*
Apache-2.0Ruby/C - Rudder - Scalable and dynamic configuration management system for patching, security & compliance, based on CFEngine. (Source Code)
GPL-3.0Scala - Salt - Event-driven IT automation, remote task execution, and configuration management software. (Source Code)
Apache-2.0Python
Related: IT Asset Management
Apache-2.0Python
GPL-2.0Python - CDS - Enterprise-Grade Continuous Delivery & DevOps Automation Open Source Platform. (Source Code)
Apache-2.0Java/Ruby - Jenkins - Continuous Integration Server. (Source Code)
GPL-3.0PHP - Virtualmin - Powerful and flexible web hosting control panel for Linux and BSD systems. (Source Code)
MITPerl - Mina - Really fast deployer and server automation tool (rake based). (Source Code)
MITNodejs - Vlad the Deployer - Deployment automation (rake based).
MITRuby
MITNodejs/Docker
BSD-3-ClauseJava
Related: DNS - Servers
MITPHP
BSD-3-ClauseC
Open-source code editors.
MITTypeScript
OLDAP-2.8C
Apache-2.0Go/Docker/K8S
IT asset management software.
GPL-3.0/AGPL-3.0OVF/Python - RackTables - Datacenter and server room asset management like document hardware assets, network addresses, space in racks, networks configuration. (Demo, Source Code)
GPL-2.0PHP - Ralph - Asset management, DCIM and CMDB system for large Data Centers as well as smaller LAN networks. (Demo, Source Code)
GPL-3.0C
- aerc - Terminal MUA with a focus on plaintext and features for developers. (Source Code)
MITGo - Claws Mail - Old school email client (and news reader), based on GTK+. (Source Code)
MPL-2.0C/C++
MITGo
Miscellaneous
GPL-2.0PHP - cadvisor - Analyzes resource usage and performance characteristics of running containers.
GPL-3.0PHP/Shell - glances - Open-source, cross-platform real-time monitoring tool with CLI and web dashboard interfaces and many exporting options. (Source Code)
QPL-1.0PHP - openITCOCKPIT Community Edition - Monitoring Suite featuring seamless integrations with Naemon, Checkmk, Grafana and more. (Demo, Source Code)
GPL-3.0deb/Docker - Performance Co-Pilot - Lightweight, distributed system performance and analysis framework. (Source Code)
EPL-1.0Java - rtop - Interactive, remote system monitoring tool based on SSH.
MITGo - ruptime - Classic system status server.
GPL-2.0C
GPL-3.0PHP
GPL-2.0Python
GPL-3.0C++
GPL-2.0Perl
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
Troubleshooting tools.
GPL-2.0C
Apache-2.0C
GPL-2.0C
GPL-2.0C
BSD-2-ClauseC - Static Web Server - A cross-platform, high-performance, and asynchronous web server for static file serving. (Source Code)
Apache-2.0/MITRust/Docker - Traefik - HTTP reverse proxy and load balancer that makes deploying microservices easy. (Source Code)
BSD-2-ClauseC
- Lecturify - a tutorials IRC chatbot with classes in unix, system administration, programming, web development, translations.
