* Added HestiaCP - Open Source Web Server Manager Co-authored-by: Rabenherz112 <rabenherz@theravenhub.com> Co-authored-by: Christoph Schläpfer <c.schlaepfer@datact.ch> Co-authored-by: nodiscc <nodiscc@gmail.com> |
| .hecat | ||
| Makefile | ||
- Miscellaneous
- Metrics & Metric Collection
- Remote Desktop Clients
- Blogs
- Books
- Newsletters
Build automation.
MITRuby
Backup software.
AGPL-3.0C/C++
MIT/Apache-2.0Python
_See also: /r/chatops*
Related: IT Asset Management
Apache-2.0Python
Apache-2.0Python
MITPerl - Mina - Really fast deployer and server automation tool (rake based). (Source Code)
MITNodejs - Vlad the Deployer - Deployment automation (rake based).
MITRuby
MITNodejs/Docker
BSD-3-ClauseJava
BSD-3-ClauseC
Related: DNS - Servers
MITPHP
Open-source code editors.
MITTypeScript
OLDAP-2.8C
Apache-2.0Go/Docker/K8S
IT asset management software.
GPL-3.0C
MPL-2.0C/C++
Miscellaneous
GPL-3.0PHP/Shell - glances - Open-source, cross-platform real-time monitoring tool with CLI and web dashboard interfaces and many exporting options. (Source Code))
QPL-1.0PHP - Performance Co-Pilot - Lightweight, distributed system performance and analysis framework. (Source Code)
GPL-2.0C
MITGo
GPL-3.0PHP
GPL-2.0Python
GPL-3.0C++
GPL-2.0Perl
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
Troubleshooting tools.
GPL-2.0C
Apache-2.0C
GPL-2.0C
GPL-2.0C
BSD-2-ClauseC
