- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- NoSQL
- RDBMS
- SSH: see awesome-ssh
- Resources
See also: IT Asset Management
- Web hosting
- DNS
- Server
DNS
Domains
Identity Management - LDAP
- OpenDJ - Fork of OpenDS.
GPL-3.0Perl - bolo - A Do-it-Yourself monitoring framework built to gather metrics, mine data and report on the systems in your network.
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
- DD-WRT - A Linux-based firmware for wireless routers and access points, originally designed for the Linksys WRT54G series. Source Code
GPL-2.0C - OpenWrt - A Linux-based router featuring Mesh networking, IPS via snort and AQM among many other features. Source Code
GPL-2.0C - OPNsense - An open source FreeBSD-based firewall and router with traffic shaping, load balancing, and virtual private network capabilities. Source Code
BSD-2-ClausePHP
Wikis
