- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- NoSQL
- RDBMS
- SSH: see awesome-ssh
- Resources
- Flynn - PaaS
MITGo - Concourse - Concourse is a CI tool that treats pipelines as first class objects and containerizes every step along the way. (Demo, Source Code)
- Web hosting
- DNS
- Server
- Camlistore - A set of open source formats, protocols, and software for modeling, storing, searching, sharing and synchronizing data.
DNS
Domains
LDAP
- OpenDJ - Fork of OpenDS.
Tools and web interfaces
- netcheck – Simple ping status system written in Java, similar to Pingdom and StatusCake.
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
- Apache - Most popular web server.
Resources
Debian-based distributions
RPM-based distributions
Wikis
