- Configuration Management
- Identity Management - Single Sign-On (SSO)
- Metrics & Metric Collection
- Miscellaneous
- PaaS
- Remote Desktop Clients
Build automation.
MITRuby
Backup software.
AGPL-3.0C/C++
MIT/Apache-2.0Python
_See also: /r/chatops*
Apache-2.0Ruby/C - Rudder - Scalable and dynamic configuration management system for patching, security & compliance, based on CFEngine. (Source Code)
GPL-3.0Scala - Salt - Event-driven IT automation, remote task execution, and configuration management software. (Source Code)
Apache-2.0Python
Related: IT Asset Management
Apache-2.0Python
GPL-2.0Python - CDS - Enterprise-Grade Continuous Delivery & DevOps Automation Open Source Platform. (Source Code)
Apache-2.0Java/Ruby - Jenkins - Continuous Integration Server. (Source Code)
GPL-3.0PHP - Virtualmin - Powerful and flexible web hosting control panel for Linux and BSD systems. (Source Code)
MITPerl - munki - Webserver-based repository of packages and package metadata, that allows macOS administrators to manage software installs. (Source Code)
Apache-2.0JavaScript/Docker - Kroki - API for generating diagrams from textual descriptions. (Source Code)
MITNodejs/Docker
BSD-3-ClauseJava
Related: DNS - Servers
MITPHP
BSD-3-ClauseC
Open-source code editors.
MITTypeScript
OLDAP-2.8C
Apache-2.0Java - Kratos - Next-gen identity server with Ory-hardened authentication, MFA, FIDO2, profile management, identity schemas, social sign in, registration, account recovery, and IoT auth. Golang, headless, API-only - without templating or theming headaches. (Source Code)
Apache-2.0Golang
GPL-2.0PHP - LDAP Account Manager (LAM) - Web frontend for managing entries (e.g. users, groups, DHCP settings) stored in an LDAP directory. (Source Code)
Apache-2.0Go/Docker/K8S
IT asset management software.
GPL-3.0/AGPL-3.0OVF/Python - RackTables - Datacenter and server room asset management like document hardware assets, network addresses, space in racks, networks configuration. (Demo, Source Code)
GPL-2.0PHP - Ralph - Asset management, DCIM and CMDB system for large Data Centers as well as smaller LAN networks. (Demo, Source Code)
GPL-3.0C
- aerc - Terminal MUA with a focus on plaintext and features for developers. (Source Code)
MITGo - Claws Mail - Old school email client (and news reader), based on GTK+. (Source Code)
MPL-2.0C/C++
MITGo
Miscellaneous
GPL-2.0PHP - cadvisor - Analyzes resource usage and performance characteristics of running containers.
GPL-3.0PHP/Shell - glances - Open-source, cross-platform real-time monitoring tool with CLI and web dashboard interfaces and many exporting options. (Source Code)
QPL-1.0PHP - openITCOCKPIT Community Edition - Monitoring Suite featuring seamless integrations with Naemon, Checkmk, Grafana and more. (Demo, Source Code)
GPL-3.0deb/Docker - Performance Co-Pilot - Lightweight, distributed system performance and analysis framework. (Source Code)
EPL-1.0Java - rtop - Interactive, remote system monitoring tool based on SSH.
MITGo - ruptime - Classic system status server.
MITGo - Status - Simple and lightweight system monitoring tool for small homeservers with a pleasant web interface. (Demo
GPL-1.0Perl - Wazuh - Unified XDR and SIEM protection for endpoints and cloud workloads. (Source Code)
GPL-2.0C - Zabbix - Enterprise-class software for monitoring of networks and applications. (Source Code)
GPL-2.0C
GPL-3.0PHP
PaaS
Platform-as-a-Service software allows customers to provision, instantiate, run, and manage a computing platform and one or more applications, without the complexity of building and maintaining the infrastructure typically associated with developing and launching the application. Also includes Serverless computing and Function-as-a-service (FaaS) software.
- CapRover - Build your own PaaS in a few minutes. (Demo, Source Code)
Apache-2.0Docker/Nodejs - Coolify - An open-source & self-hostable Heroku / Netlify alternative (and even more). (Source Code)
Apache-2.0Docker - Dokku - An open-source PaaS (alternative to Heroku). (Source Code)
MITDocker/Shell/Go/deb - fx - A tool to help you do Function as a Service with painless on your own servers.
MITGo - Kubero - A self-hosted Heroku PaaS alternative for Kubernetes that implements GitOps. (Demo, Source Code)
GPL-3.0K8S/Nodejs/Go - LocalStack - LocalStack is a fully functional local AWS cloud stack. This includes Lambda for serverless computation. (Source Code)
Apache-2.0Python/Docker/K8S - Nhost - Firebase Alternative with GraphQL. Get a database and backend configured and ready in minutes. (Source Code)
MITDocker/Nodejs/Go - OpenFaaS - Serverless Functions Made Simple for Docker & Kubernetes. (Source Code)
MITGo - Tau - Easily build Cloud Computing Platforms with features like Serverless WebAssembly Functions, Frontend Hosting, CI/CD, Object Storage, K/V Database, and Pub-Sub Messaging. (Source Code)
BSD-3-ClauseGo/Rust/Docker - Trusted-CGI - Lightweight self-hosted lambda/applications/cgi/serverless-functions platform.
MITGo/deb/Docker
GPL-2.0Python
See also: Cloud Native Landscape - Streaming & Messaging
BSD-3-ClauseC++ - NSQ - A realtime distributed messaging platform. (Source Code)
MPL-2.0Go - ZeroMQ - Lightweight queuing system. (Source Code)
GPL-3.0C++
GPL-2.0Perl
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
Troubleshooting tools.
GPL-2.0C - Sysdig - Capture system state and activity from a running Linux instance, then save, filter and analyze. (Source Code)
GPL-2.0C
Apache-2.0C
GPL-2.0C
- DefGuard - True enterprise WireGuard with MFA/2FA and SSO. (Source Code)
Apache-2.0Rust - Dockovpn - Out-of-the-box stateless dockerized OpenVPN server which starts in less than 2 seconds. (Source Code)
Apache-2.0Docker - Gluetun VPN client - VPN client in a thin Docker container for multiple VPN providers, written in Go, and using OpenVPN or Wireguard, DNS over TLS, with a few proxy servers built-in.
MITdocker - Headscale - Self-hostable fork of Tailscale, cross-platform clients, simple to use, built-in (currently experimental) monitoring tools.
GPL-2.0C - SoftEther - Multi-protocol software VPN with advanced features. (Source Code)
GPL-2.0C
Please visit awesome-selfhosted/Web Servers
