- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- NoSQL
- RDBMS
- SSH: see awesome-ssh
- Resources
- Lsyncd - File Monitor which spawns a process to synchronize the changes (rsync by default).
- Flynn - PaaS
MITGo - Concourse - Concourse is a CI tool that treats pipelines as first class objects and containerizes every step along the way. (Demo, Source Code)
- Web hosting
- DNS
- Feathur - VPS Provisioning and Management Software.
- WebVirtMgr - libvirt-based Web interface for managing virtual machines.
- Server
- Camlistore - A set of open source formats, protocols, and software for modeling, storing, searching, sharing and synchronizing data.
- MooseFS - Fault tolerant, network distributed file system.
DNS
Domains
LDAP
- OpenDJ - Fork of OpenDS.
Tools and web interfaces
- Shinken - Another monitoring framework.
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
- Apache - Most popular web server.
Resources
Debian-based distributions
RPM-based distributions
Wikis
