| .hecat | ||
| Makefile | ||
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metric & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
- CoreDNS - Flexible DNS server. (Source Code)
- djbdns - A collection of DNS applications, including tinydns. (Source Code)
- dnsmasq - Provides network infrastructure for small networks: DNS, DHCP, router advertisement and network boot. (Source Code)
- Knot - High performance authoritative-only DNS server. (Source Code)
- NSD - Authoritative DNS name server developed speed, reliability, stability and security. (Source Code)
- PowerDNS - DNS server with a variety of data storage back-ends and load balancing features. (Source Code)
- Unbound - Validating, recursive, and caching DNS resolver. (Source Code)
- Yadifa - Lightweight authoritative Name Server with DNSSEC capabilities powering the .eu top-level domain. (Source Code)
DNS server control panels.
MITPython
OLDAP-2.8C
GPL-3.0C
Collectors only
Dashboards
Storage
GPL-3.0PHP
BSD-2-ClauseCPHP
GPL-2.0C
MITC/Docker - Varnish - Web application accelerator/caching HTTP reverse proxy. (Source Code)
BSD-2-ClauseC
