| .hecat | ||
| Makefile | ||
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metrics & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
MITRuby
- Proxmox Backup Server - Proxmox Backup Server is an enterprise-class, client-server backup solution thatis capable of backing up virtual machines, containers, and physical hosts. (Source Code)
GPL-3.0Rust - rclone - a command line program to sync files and directories to and from several cloud storage systems/providers.
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
BSD-3-ClauseJava
BSD-3-ClauseC - PowerDNS Authoritative Server - Versatile nameserver which supports a large number of backends.. (Source Code)
BSD-3-ClauseC
DNS server control panels.
ISCPerl - Pi-hole - A blackhole for Internet qdvertisements with a GUI for management and monitoring. (Source Code)
EUPL-1.2Shell/PHP - Poweradmin - Web-based DNS control panel for PowerDNS server. (Source Code)
GPL-3.0PHP
MITPython
OLDAP-2.8C
GPL-3.0C
See also: Metrics & Metric Collection
See also: Databases, Monitoring
MITGo
GPL-3.0PHP
GPL-2.0Python
GPL-3.0C++
Apache-2.0Shell/PHP/Other
GPL-2.0C
BSD-2-ClauseC
